Latest post 11-01-2008 6:27 PM by moxxey. 6 replies.
Page 1 of 1 (7 items)
  • 10-31-2008 4:19 PM
    Beovision 7 and sky
    Ever since my dealer has done some work on my TV, whenever I go into sky the screen curtain opens to reveal a blank scrren and then the programme appears a couple of seconds afterwards - a small point, perhaps, but annoying nevertheless, because the effect is spoiled.  This has never happened before.  On terrestrial TV, there is no problem, the curtain opens to reveal the programme being broadcast.
    Is it simply a matter of an adjustment in the menu?
  • 10-31-2008 5:02 PM In reply to
    • moxxey
    • Top 25 Contributor
    • Joined on 04-14-2007
    • South West, UK
    • Posts 2,360
    Re: Beovision 7 and sky
    No, this is absolutely standard on the BV7 with Sky. It happened with a recent software update. I think sw 4.17.
    Reason? The Sky box has to handshake with your TV, so the BV7 doesn't show the image for some time after starting up. It *is* annoying, I know. It never used to be as long as this - sometimes it can be up to 15 seconds after you turn on the TV!
  • 11-01-2008 3:51 AM In reply to
    http://forum.beoworld.org/forums/thread/152758.aspx
  • 11-01-2008 10:30 AM In reply to
    Thanks, that's reassuring but it never used to be like that and the work I mentioned didn't involve any software updates
    I have a mark ii, not a mark iii, I don't knopw whether that's significant
  • 11-01-2008 1:21 PM In reply to
    • moxxey
    • South West, UK
    • Posts 2,360
    thorne:
    Are you sure? The dealer can't do a huge amount with your TV apart from sw upgrades. You might not have even noticed?
    However, one thing might have changed - they might have changed the HD module in your BV7, which will include the latest sw for the module, which could be the reason for the change.
    As I said, it's a really annoying situation and, as you said, it didn't happen in the past. I noticed it after a recent sw upgrade earlier this year. The curtains should open straight in to the TV programme. With Sky, it doesn't. Curtains open and then we have to wait some more for the picture. With SD or digital TV, the curtains open and the picture appears immediately.
  • 11-01-2008 5:39 PM In reply to
    The work involved was to do with the faulty motorised stand, not the TV at all but they had to dismantle all the wiring and take the TV off its stand.
    Also, my BV7 is HD ready of course, but I do not have a sky HD box so do not watch anything in HD
  • 11-01-2008 6:27 PM In reply to
    • moxxey
    • South West, UK
    • Posts 2,360
    thorne:
    Your subject line was 'with Sky', so I assumed you were using HDMI, which is a reason why you get the delay after opening the curtains.
    If you don't know what happened, you are best asking your dealer. If they didn't update the sw or change a module, there's no way your TV could have had this effect....unless you didn't notice it previously.
