Does anyone have an issue with the Logitech Harmony One in controlling the volume on a Beosund?
The remote control works as per the command volume up and down but the volume increase & decrease interval amount is 6 steps instead of the usual 2 steps. So If you are in volume 30,One tap of the Harmony would increase it to 36 instead of 32, I tried playing around in the "Input Delays" setting but to no resolution.
