We have an AVANT DVD in our lounge connected to a SKYHD + box by scart and also an infrared lead.
The same SKYHD is connected to a Beovision 7 which is the master TV.
In other link rooms we have Beovision 6 TVs.
The problem we have is as follows:
1. Starting with the AVANT switched on viewing SKYHD.
2. Next switch the Beovision 6 on in a link room.
3. Then switch the AVANT off.
This switches the SKYHD off in the link room and we are unable to switch the SKYHD back on in the link room.
Finally, to complicate matters further we also have a normal SKY+ box connected to the Beovision 7 and is able to be used as V Aux on all TVs.
What do we do to enable ourselves to switch off the AVANT without it also switching off the SKYHD everywhere else?
It seems the 'SAT' or DTV button on the remotes when used on the Beovision 6 is sending a 'standby command' to the SKYHD?
The work round we are using at the moment is to press V-AUX on the Beovision 6, this switches on the SKY+ and the SKYHD.
I've set the Beovision 7 to never send a standby message to the SKY HD.
Any advice or ideas would be appreciated.
Thanks,
Rob
