Latest post 06-17-2007 4:27 PM by Jackmasterfunk. 8 replies.
Page 1 of 1 (9 items)
  • 04-13-2007 2:56 PM
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Help with speaker connections PC2
    At the moment I have my standard PC speakers connected to my sound card. I can listen to Nradio, Nmusic and DTV from my Avant on my PC speakers but if I click Radio I have to unplug the speakers from the sound card and plug them into the blanked off socket on PC2.
    It's a bit of a pain in the butt keep swapping the plug about. I have a little cable from my sound card into my Hauppuage TV card.
    Any advice?
    Andy T.
    Poor me, never win owt!
  • 04-13-2007 3:10 PM In reply to
    Re: Help with speaker connections PC2
    Can you not run a cable from the output of the PC2 to the input of the sound card? I seem to doing something like that when I had a PC.
  • 04-13-2007 3:31 PM In reply to
    • Jandyt
    • Posts 13,004
    Problem is that the sound card only has two inputs. One has my Haupp in and the other has my speakers.
    Andy T.
  • 04-13-2007 3:39 PM In reply to
    I use a splitter - two input sockets going into one jack.
  • 04-13-2007 3:46 PM In reply to
    • Jandyt
    • Posts 13,004
    Never thought of that! Couldn't see the wood for the trees. I've loads of other PC2 questions but it won't be long before Santiago joins us so I'm going to save them.
    Cheers PeterSmile
    Andy T.
  • 04-19-2007 4:34 AM In reply to
    As Peter said, a splitter cable is a good solution in this case.
    I also used always the PC2 headphones output for the standard PC speakers, you don't need plug-unplug them anymore and it works very well.
    Santiago
  • 04-19-2007 8:36 AM In reply to
    • Jandyt
    • Posts 13,004
    What a good idea Santiago, I'll probably mess with that tonight.
    Andy T.
  • 04-21-2007 6:54 AM In reply to
    • olluf
    • Not Ranked
    • Joined on 04-18-2007
    • Netherlands
    • Posts 18
    I connected my (Altec Lansing) active speakers to the powerlink connector of the PC2 with a converter from DIN/cinch/minijack. All B&O and PC sound sources available without problem!
  • 06-17-2007 4:27 PM In reply to
    hello sorry for being lait for the signal to your splitter you can us the Audio out insted of headspeaker out , on beoport it works well
    wer ist der grössere narr , der oder der der ihm folgt.
