I bought a MX5500 model 3621 MDT. and I'm using a Beo 4 as remote.
I have problems to get the TV to sync on 16:9 picture format. It seem to sync OK with 4:3, though.
I connected a DVB-C STB into AV2 and there was an asterisk for that input in the menu. With this 4:3 was OK, but 16:9 did not sync. Then I changed setup to Decoder, and I got a 4:3 picture, no matter what the format of the picture really is.
I tried to use the FORMAT in beo 4, mostly nothing happens, and in one point, I got all formats not syncing. With "not syncing" I mean, that picture rolls both horizontally and vertically and no sound.
Is it possible, that this TV does not support 16:9 at all, or is it just question of setup?
BR,
Pekka
