Latest post 10-07-2008 8:49 AM by Peter. 13 replies.
Page 1 of 1 (14 items)
  • 08-25-2008 2:43 PM
    • Mohawk
    • Top 500 Contributor
    • Joined on 01-30-2008
    • Sweden
    • Posts 103
    • Gold Member
    Beogram 6002
    Hi
    I need the plastic back part (part no 3030067) that holds the lid and dustcover in place for my bg6002 because the hinges for the dust cover are broken. Is there anyone here who may have this part?
     /Fredrik
    Filed under:
  • 08-26-2008 10:09 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beogram 6002
    Have you asked B&O ? Last time I needed one, they were still available and that was about 2-3 years ago.
  • 08-26-2008 11:21 AM In reply to
    Re: Beogram 6002
    Fredrik:
    Are the hinges where the rod threads through broken or the plastic tab that holds the back part to the chasis broken?
    If it just the tab you can use a good quality double sided tape to keep it from "bowing."
    Derek
  • 08-26-2008 11:50 AM In reply to
    • Mohawk
    • Sweden
    • Posts 103
    • Gold Member
    Re: Beogram 6002
    Hi Derek and Martin
    It is the hinges where the rod threads through that are broken on the plastic back part not on the lid or dustcover. They are broken just above the spring mechanism that holds the dustcover in upright position.
    I've asked b&o of sweden for replacement but they said that this part was obsolete.
    /Fredrik
  • 08-26-2008 3:02 PM In reply to
    Re: Beogram 6002
    Hi Fredrik:
    That's a tricky one. I'm not sure that even if you did find a replacement, how much longer it would last as the plastic becomes brittle with time. That whole dust cover design including the adhesive metal cover was simply poorly designed in my opinion. Also the tension on the spring should never have been set so high.
     The best thing to do at this point (until you find a replacement, or until Dillen comes up with a solution (he always does)) is to reduce the tension on the spring to keep the dust cover from warping. This will mean that dust cover won't stay up by itself but it will keep the cracks from propagating.
    At this point all 8000/6000 series owners should be reducing the tension on the dust cover spring in general so as extend the life of that back piece.
     Derek
  • 08-26-2008 3:45 PM In reply to
    • henrik
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Stockholm, Sweden
    • Posts 299
    Re: Beogram 6002
    Derek,
    Great tip! How do I adjust the tension? i really want to do this on my BG8002, the dustcover is badly warped now and it's only a question of time before the mechanism breaks - it did on my bg8000 a couple of weeks ago :-(
  • 08-26-2008 4:32 PM In reply to
    • Mohawk
    • Sweden
    • Posts 103
    • Gold Member
    Re: Beogram 6002
    Hi
    I managed to glue the hinges back to position again. I also reinforced the hinges on the back part by filling the rectangular holes under the hinges with epoxy glue so the stress on the corners of those holes (it's in those corners the hinges cracked) were reduced by spreading it over a larger surface. It looks and works fine. I brought the spring up to original tension without problems. I agree with Derek that owners of "uncracked" units should release the tension at least to the point where the dust cover just can stand up i fully open position. The adjustment screw is located under the plastic cover over the tangential arm track, approx 8cm left of the spring mechanism that lift the dust cover. 2mm allen key needed. To loosen tension - turn key counter clockwise.
    Btw if someone have the back part I'm still interested as a future spare.
    /Fredrik
  • 08-26-2008 4:56 PM In reply to
    • Dillen
    • Posts 5,008
    Re: Beogram 6002
    Could you take a photo or two for us ? I really would like to see it.
  • 08-27-2008 6:24 AM In reply to
    • Mohawk
    • Sweden
    • Posts 103
    • Gold Member
    Re: Beogram 6002
    Hi
    If I did right - the photo is attached
    /Fredrik
  • 08-27-2008 6:25 AM In reply to
    • Mohawk
    • Sweden
    • Posts 103
    • Gold Member
    Re: Beogram 6002
    More...
  • 08-27-2008 6:37 AM In reply to
    • Mohawk
    • Sweden
    • Posts 103
    • Gold Member
    Re: Beogram 6002
    Here is a schematic drawing of what I have done to fix the hinges. My camera had trouble to shoot the details at a close distance - so I made a drawing of it to explain.
  • 08-27-2008 8:33 AM In reply to
    • Medogsfat
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Beogram 6002
    I have a Beogram TX parts machine & I'm pretty sure the lid mechanism is identical.
    Drop me a PM if you're interested in any parts, the lid mechanism is fine BTW.
    chris.
  • 10-07-2008 4:58 AM In reply to
    Re: Beogram 6002
    Hello guys,
     I am new here but was wondering if you guys could give me some advice on a Beogram 6002. I recently "found" one in my parent's garage, where it's been sitting for 10 years or so. Now it seems that it is slightly broken here and there and I was wondering if it was in any way fixable.
    First off, the metal cover on the right seems to be unglued. I figure this just needs some strong glue and should be ok, no?
    More serious, the stylus was all twisted and when I touched it it basically fell off. Is there anything I could do with this? Is there any point getting in touch with B&O?
    Thanks in advance for the help!
  • 10-07-2008 8:49 AM In reply to
    Re: Beogram 6002
    The metal plate will just glue back on - they all fall off because they were originally stuck on with two sided tape which has rotted. I use two pack epoxy. You need to clean all the black goo off the plate and the hinge though first!
    If the stylus has fallen off, you need a new cartridge and the best place to go is Soundsmith. Not cheap though so make sure the deck is worth it first!
