Latest post 10-12-2008 4:11 AM by Keith Saunders. 5 replies.
Page 1 of 1 (6 items)
  • 10-11-2008 2:47 PM
    Strange One for the technical of you
    my setup
    BV7-40mkiii with 4 x BL6000 and BL7.1  yes its a 7.1 master link to BS3000 and BL3500
    on only one of the BL6000 we pick up when switched on classic fm,  so when you mute the TV you hear very very faintly classic fm,  I ahve swapped around the speakers and its not them, could this be to do with the powerlink cable.
  • 10-11-2008 5:25 PM In reply to
    Re: Strange One for the technical of you
    It would be nice to see your set !
    Sound interesting Yes -  thumbs up
    when your Black Label begin to taste like juice just take shot or two of Absinthe and after that quench with some vodka, if you still feel juice like take beer with grappa !
  • 10-11-2008 5:39 PM In reply to
    Had a similar problem, that stopped when I reconnected properly some scart cables. Weird!?!
  • 10-11-2008 6:36 PM In reply to
    Hi:
    I know nothing of the modern cable and connection standards as I am deliberately staying with CRT. That said, this sounds like a shielding issue with your connections. If you are using scarts (prob not) buy proper shielded ones and the same applies for all other connectors.
    I am feeling around in the dark yet am almost certain that this is what it is - my friend had a big Marshall guitar amp, effects pedal and electric guitar all connected up with a mass of tangled phono cables and he could pick faint radio broadcasts too. Whenever there is a mass of cabling connected to speakers this seems to be an issue.
    Graham
  • 10-11-2008 11:50 PM In reply to
    • Russ
    • Top 100 Contributor
    • Joined on 05-07-2007
    • Washington, DC USA
    • Posts 641
    Graham,
     If it makes you feel better, there are people in Greensboro, North Carolina USA who can sometimes pick up Radio Free Europe and Voice of America on cast iron cookware!
    I agree with the  crowd, a bad cable or connection is the likely cause.
    We kid because we love.
    Bang & Olufsen Tysons Galleria
    McLean, VA USA
  • 10-12-2008 4:11 AM In reply to
    Your problem is fairly common and is most likely caused by either a bad ground connection or an earth loop.
    You pick up classic FM normally because the wire/cable in question just happens to be the length near or equal to the standing frequency or sub-divisions of the broadcast frequency.
    Clearly the first focus should be the powerlink cables and I suggest to prove if that is where the problem is you connect a wire between the screen of the powerlink plug and mains earth. If classic FM goes, then you have found the area of the problem.
    Regards Keith....
