Latest post 10-14-2008 9:13 AM by Russ. 6 replies.
Page 1 of 1 (7 items)
  • 10-11-2008 9:54 PM
    • venket
    • Not Ranked
    • Joined on 10-12-2008
    • Posts 3
    Beosystem 6500
    I need help.My CD and Tape recorder would not open. Any solution.
    Thank you in advance
  • 10-12-2008 4:25 AM In reply to
    Re: Beosystem 6500
    Take the top off and investigate! Did it happen suddenly or have you just got them? The tops are held by two clamps at the back - they should be marked on a diagram underneath the units. Loosen them and the top slides forward a bit and then lifts off.
  • 10-12-2008 8:45 AM In reply to
    • venket
    • Not Ranked
    • Posts 3
    Re: Beosystem 6500
    I have them for 20yrs. It happened suddenly. Everything functions but I cannot open them to play new Cd or Tape.
  • 10-12-2008 8:52 AM In reply to
    Re: Beosystem 6500
    Seems strange that both go at the same time. I take it that you have done the switch off at mains for 5 minutes trick? Is there any click when you press the open side?
  • 10-13-2008 12:19 PM In reply to
    • Russ
    • Top 100 Contributor
    • Joined on 05-07-2007
    • Washington, DC USA
    • Posts 641
    Re: Beosystem 6500
    Have you moved them recently?
    We kid because we love.
    Bang & Olufsen Tysons Galleria
    McLean, VA USA
  • 10-13-2008 6:33 PM In reply to
    • venket
    • Not Ranked
    • Posts 3
    Re: Beosystem 6500
    No
  • 10-14-2008 9:13 AM In reply to
    • Russ
    • Posts 641
    Re: Beosystem 6500
    On occasion, I have seen pieces in that family in which the switch that activates the door/drawer has slipped out of position to the left or right.  If this is the case then it is a relatively cheap fix, but it is a good opportunity to have the whole unit checked out.
    McLean, VA USA
