I am looking at buying a set of Beolab 9 to connect to a non B&O equipment.
I have been advised by a dealer that you can use the headphone jack from the equipment in my case it is a LG Rear Projection TV to connect to the Beolab 9.
TV->Headphone->Line into Beolab9
Apparently In doing it that way above in the long run, I also have been advised that it will damage the speakers. As it might drive the volume too high as there is no control module as such to limit the volume in case of damage.
They have recommended using a Beoport to act as a "middle" control box as such to solve that issue above.
TV->Headphone->Beoport->Beolab9
Some Questions that I have is;
Can anyone shed some knowlege in regards to this particular setup?
It is best to run it through a Beoport so it uses the full DIN plugs instead of a single plug?
Will there be any quality loss using the above 2 methods?
Thanks!
