Latest post 10-07-2008 2:15 AM by Dillen. 1 replies.
Page 1 of 1 (2 items)
  • 10-06-2008 9:41 PM
    • egamac
    • Not Ranked
    • Joined on 10-07-2008
    • Posts 1
    Beocenter 7700 Shuts Off
    I've had a Beocenter 7700 for about a year now and today my wife tried to play the radio.
    She pressed a bunch of buttons on the Tuner side and the pre-programed numbers side.
    Now when I press the PH or the tape button the machine turns on for about 5-15 seconds and automaticly
    shuts down.  I figured she programed the timer or something do with the automation, but nothing seems to work.
    If anyone has an advise it would greatly be appreciated.
    Filed under:
  • 10-07-2008 2:15 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beocenter 7700 Shuts Off
    Hi and welcome to Beoworld !
    First make sure to reset all programming by disconnecting from mains for a couple of minutes.
    If this doesn't solve the problem, it will probably need a light servicing, maybe the amplifier idle currrents need fixing.
