Could anyone possibly help?
When i attempt to connect the Beogram 3500 deck to the Beocenter phono output the signal/sound is terrible. However when i connect through the AUX on the the Beocenter the signal/sound is fine.
I'm connecting using the factory fitted 7 pin din plug.
Could there be a problem with the Beocenters phono output or am I missing something.
If you can help, please email.
Thanks in advance.
Steve
