Latest post 10-01-2008 11:33 AM by joeyboygolf. 11 replies.
Page 1 of 1 (12 items)
  • 09-27-2008 5:47 PM
    • benkap
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Oslo, Norway
    • Posts 162
    MX4000 speaker problem
    My lovely black MX4000 has been allowed down from the attic and into the bedroom by SWMBO.
    Unfortunately, only the left speaker is working. It is not due to balance settings, I've tried that. The MX4000 has been moved from Copenhagen to Oslo and been stored since then and I am not certain if the right speaker worked before.
    Is this something that could be caused by bad capacitors or should I expect the speaker to be faulty?
    Thanks Smile
  • 09-28-2008 12:18 AM In reply to
    Re: MX4000 speaker problem
    I have had problems in the past with the plug/socket on the main board where the speaker connects.
    Regards Graham
  • 09-28-2008 5:11 AM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    salut
    do the speakers have separate plugs or is it just a double type - if separate try reversing the plugs if the one cahnnel is still down could be the output transistor amp - had this prob with a 5500 - easy task replacing if you have a so0lder sucker etc
    tony s
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 09-29-2008 5:57 AM In reply to
    • benkap
    • Oslo, Norway
    • Posts 162
    joeyboygolf:
    Thank you both for you answers. Graham, looking at the service manual wiring diagram - are the plugs/sockets labelled P49/P50 or are these for external speakers?
    I don't have any skills in this area so if it is something more complicated than absolutely not at all complicated I would have to have someone else look at it Wink
  • 09-29-2008 3:39 PM In reply to
    • benkap
    • Oslo, Norway
    • Posts 162
    Got home from work and unscrewed the back of the MX4000.
    Locating the speaker plugs was easy enough. Indeed as you proposed, Graham, one plug wasn't entirely in its place.
    Unfortunately that didn't do it - turns out the speaker also has foam rot Hmm. Strangely, the right speaker was far worse than the left one and as the right speaker is still not working I fear that it needs to be replaced completely.
  • 09-29-2008 3:53 PM In reply to
    In my experience the speakers usually have foam rot but it does'nt stop them from working. I suggest a PM to nobby who has much knowledge of MX's.
    Another thing to try is to switch the sound output to MONO and see if both speakers work this tests out the Nicam board. I freely admit that I have learnt all this MX stuff from nobby so you are better off dealing direct with the main man!
    Regards Graham
  • 09-30-2008 3:46 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    hi
    as previously check the speakers by swapping the plugs if same channel down ie left original and right after swap then its likely speaker or try each plug in working channel
    tonyb s
  • 09-30-2008 3:24 PM In reply to
    • benkap
    • Oslo, Norway
    • Posts 162
    Thanks, Tony!
    I will definitely try and swap the speaker plugs. For some odd reason I didn't try that yesterday Huh?
    I will contact Nobby with any additional questions. Thanks to you too, Graham!
  • 09-30-2008 3:44 PM In reply to
    I had an MX5500 with same fault!
     But my guess...  MX4000 + storage = dry joint.  Is there sound in both channels from the headphone output so we can eliminate everything to do with reception, audo demodulation + decoding and preamplification.  Leaving only the power amp stage (+ associated Power Supply) and connections.  Having said all that, to test these things then you need the TV set ON.  AND if you're not an experienced engineer then running the TV with the back off is a hazzard (think people sometimes forget on here), so stay safe. Smile
    Jack
    BV10(40) BV8-32, BV3-32, MX7000, DVD1, HDR1, V8000
    Beomedia-1, BS9000, BC7002, BC2300, BS5500, BM6500, BGCD6500, BM1900-2
    BL5, BL8000, BL6000, BL Penta3, BL3500
    Beovox MC120.2, 3000 Panels, CX50s, C75s, AND LOTS WIRES, BOOkS, MAGS n BITS (ebay sales: beo-store-uk)
  • 09-30-2008 3:55 PM In reply to
    • benkap
    • Oslo, Norway
    • Posts 162
    Will check the headphones tomorrow Smile
    I am the first to say that I shouldn't try testing anything with the back off and the power on, I am very well aware of my limitations in that field Wink
  • 10-01-2008 11:13 AM In reply to
    • benkap
    • Oslo, Norway
    • Posts 162
    Have switched the R/L speaker plugs just now. Still only sound in the left speaker.
    Headphones have sound in both channels.
    Can I assume anything else than that the right speaker is defective in some way?
  • 10-01-2008 11:33 AM In reply to
    Swap the speakers over!
    Regards Graham
