Latest post 10-01-2008 5:19 AM by tonyfree2010. 2 replies.
Page 1 of 1 (3 items)
  • 09-30-2008 5:22 PM
    Instruction on how to mount Beolab 2000
    Has anyone got the instruction on how to mount Beolab 2000 pls? I want to move my unit from the bedroon to the kitchen and cant find where i kept the small booklet that came with the system when i bought it new over 3 years ago.
    Any useful link or where i get this will be useful.
    Regards,
    Tony
  • 09-30-2008 5:40 PM In reply to
    • Opman
    • Top 200 Contributor
    • Joined on 12-31-2007
    • Cheshire, UK
    • Posts 323
    Re: Instruction on how to mount Beolab 2000
    Hi Tony
    It's not really the instruction book you need. It's the wall bracket itself. This would have been supplied new and is nothing than a square ish metal wall plate that has hooks on it. You simply fix the plate to the wall and the Lab2000 slides on from the right side and locates in place.
    There was also an optional corner bracket that allowed the Lab2000 to sit across a right angle. You mount the supplied square plate onto the corner bracket and the fit the Lab2000 as normal.
    Both brackets are no longer made but I'm sure you will be able to pick up one or both second hand if you need them.
    Opman
  • 10-01-2008 5:19 AM In reply to
    Thanks Opman, i have the bracket and some screws i saw in the box. I'll get cracking on that then....
    regards
    Tony
