Latest post 09-27-2008 4:16 PM by joeyboygolf. 4 replies.
Page 1 of 1 (5 items)
  • 09-27-2008 11:56 AM
    Beolab 2500 Speakers with Beocenter 9500
    Hi, I recently purchased a pair of Beolab 2500 and actually heard them working before I took them home; they sounded great and were hooked up to a Beosound 3000.
     I also recently purchased a Beocenter 9500 but never heard it play before it was shipped.
    When I paired the two using the cables that came with the Beolabs I cannot get the sound to come out more than a wisper even at the highest setting.  Everything appears to be working fine on the BC 9500 so I think I must have installed them improperly or don't have the sound setting configured for the active speakers.
    Any help would be greatly appreciated.
     Pete
    Filed under:
  • 09-27-2008 1:15 PM In reply to
    Re: Beolab 2500 Speakers with Beocenter 9500
    There is no configuring to do on the 9500 so suggest that you try another set of speakers. Do ypu have a set of passives that you could try?
    Have you tried a pair of headphones?
    Could be that the line in/out dummy plug is missing? (a white disc shaped plug in the socket bay)
    Regards Graham
  • 09-27-2008 1:47 PM In reply to
    Is the LED colour changing to green on the speaker?
  • 09-27-2008 4:06 PM In reply to
    Graham,
    That's it!  I removed the dummy plug before setting it up and my wife had actually thrown it away.  I retrieved it after getting your response and it works great.
     Thanks for the quick reply!!
    Pete
  • 09-27-2008 4:16 PM In reply to
    pjorde:
    Graham,
    Pete
    You are not the first and you will not be the last!
    Regards Graham
