Latest post 09-26-2008 6:10 PM by Peter. 1 replies.
Page 1 of 1 (2 items)
  • 09-26-2008 5:28 PM
    Beomaster 3000-new owner question
    I just purchased a Beomaster 3000 and need the antenna assembly (rabbit ear type with mount)...any ideas on how to locate one. Also the aluminum "deck" that covers the controls is not aligned, meaning there is wider gap on one side as you look down on the unit. Is there an easy way to align this? Lastly, is there a way to bypass the AMP in the unit and use an external amp? Thanks! Tom in North Carolina.
    Filed under:
  • 09-26-2008 6:10 PM In reply to
    Re: Beomaster 3000-new owner question
    Which Beomaster 3000 - there are two basic types. One has piano keys and the other is touch sensitive. I would use a normal internal aerial - the rabbit ears were never that great in my experience. A good external FM aerial would be even better.
    Not that easy to bypass the power amplifier - you can get line out via the tape but you would then need a pre-amp to control the volume.
