1st March February 2012
Latest post 09-23-2008 9:15 AM by Santiago. 7 replies.
09-22-2008 2:36 PM
Ehlerz
- Joined on 04-17-2007
- DK
- Posts 510
"Scene" function not working right..or what??
Hi I am in the process of programming my Beo5 but am experiencing some difficulties. Basically everything is fine however, when i choose "DTV", and then "Scene" it is not possible for me to turn the Stand. On BEO4 you can at any time press list, stand and then rotate your tv regardless of what source is chosen. Why is this? If i would like to add "Speaker" in one of my zones instead of "Scenes", this is not possible... What am i doing wrong... It seems that the Scene "Stand" is only active if i choose DVD or TV in one of my zones, why cant i decide myself when and where i would like the button "Stand" to be on my remote?
BV7-40 MK IV, BL5´s, BL3´s, BL 3500, BL7-4, BS3000, BC 6-23, BV 1, BS3.
PhilLondon
- Joined on 04-16-2007
- London
- Posts 2,545
Re: "Scene" function not working right..or what??
Do you have a stand button, after you have pressed Scene? Which TV have you got?
Ehlerz
- DK
- Posts 510
wtlc2zpx: Do you have a stand button, after you have pressed Scene? Which TV have you got?
Hi The Stand button is always there if i press Scene, however it is not always possible to use it(grayed out) as this depends on what menu i am operating in. If i am operating in CD for an exampel, pressing scene will not allow me to turn my stand, probably because the remote "sees" no use in beeing able to opperate a stand when listning to a CD. However, on the Beo4 you can at ANY time chose to turn your tv by pressing list, stand etc. Is there no way i can tell my remote that the scenebutton "Stand" should always be active? Seems you do not have that oppotunity in the setup software. Btw, my tv is a 7-32 MKII.
Santiago
- Switzerland
- Posts 3,286
Ehlerz: However, on the Beo4 you can at ANY time chose to turn your tv by pressing list, stand etc.
When listening a CD in my linked BS9000, the avant stand never works (Beo4/Beo5) because the avant screen is off, even if the command is always present in the beo4. That's why is normal for me to see this option greyed out in my beo5 in that case, and I've never missed it.
The avant stand only works when the screen is on (so it does even when using the AV function) but maybe with a BV7 this is completely different... does it?
If you want this stand commands always on, I would try to make a brand new "stand" button from scratch, out of the scene screen section. Ehlerz: If i would like to add "Speaker" in one of my zones instead of "Scenes", this is not possible... What am i doing wrong...
If you cannot use the "speaker" button already present in the scene screen which has been automatically created by the software (copy - paste) then you can create a brand new one by your own from scratch. I've done it in this way, and all the "speakers..." commands in my scene screens works fine.
Regards
Ehlerz
- DK
- Posts 510
Santiago: Ehlerz: However, on the Beo4 you can at ANY time chose to turn your tv by pressing list, stand etc.
Regards
Hmm, how did you do that?? I tried aswell to make my own speaker button but i have no IR for "Speaker" in my setup software, only "Sound". Furthermore i cant seem to find "Stand" either. After pressing "new button" i choose "IR", "TV" for an example and then scroll to find "Stand" which is not there. Can you please tell my how to do it? TIA
Ehlerz
- DK
- Posts 510
To be more specific... i would like a speaker and a Stand button somwhere else than under "Scenes". For an example it would be nice to have on the first page of each of my zones. Is this possible or do you have to create them under "Scenes"?
Santiago
- Switzerland
- Posts 3,286
Re: Scene function not working right..or what??
it would be nice to have on the first page of each of my zones. This could be the first page of my zone "SALON" where "speakers..." and "stand..." commands works fine, outside of "scenes" screen. I must repeat: stand commands only works when my avant screen is ON i would like a speaker and a Stand button somwhere else than under "Scenes"
If I remember well I could copy the "stand..." and "speaker..." commands from the "scenes" screen, to paste it inside any "zone" screen without problem
Santiago
- Switzerland
- Posts 3,286
Re:Scene function not working right..or what??
Ehlerz: Hmm, how did you do that?? I tried aswell to make my own speaker button but i have no IR for "Speaker" in my setup software, only "Sound".
That is the command you must use, followed of a "0:000:TV:CIFFER_#" command
Page 1 of 1 (8 items)
