Thanks Bob, that explains a lot.
 As for the improved CD mechanism you refer to, am I correct that it was the mechanism with the vertical tracking lens versus the arc tracking lens of the 2500?
 An if so, do you know if they made any 2500's with the new vertical tracking lens?
 Pete
