Latest post 09-11-2008 10:55 PM by drevil2k2. 2 replies.
Page 1 of 1 (3 items)
  • 09-10-2008 7:05 PM
    Bezerk Beosound 3
    So the other night, I came home to some music from the BS3, but I did not turn it on or used the timer. When I attempted to push stop and standby, nothing happened.
    When I tried to turn down the volume, it started to scan my radio stations. I gently place the unit in the trunk of my car in the garage.
    Is there a hard reset for this unit? I
    think the battery has been discharged, but don't want to charge up this demon once again.
    Any thoughts?
  • 09-11-2008 3:08 PM In reply to
    Re: Bezerk Beosound 3
    I think some of the early models developed a fault on the keypad. That could be it.
    Would be covered by warranty though.
    Cheers
    JK
  • 09-11-2008 10:55 PM In reply to
    Thanks, will check with the local B&O store.
