I am new to this forum, and have read several responses regarding irregular 33 rpm speed on a 4002.
My
4002 was rebuilt about 10 years ago using B&O parts. Since that
time, it hasn't been used enough to wear out the motor, but when I play
a record the speed sounds as it should initially, but a few minutes
later the speed varies noticeably.
I removed the top cover and
the belt looks fine (and doesn't slip when I hold the platter while the
motor turns). I then removed the platter and the only possible issue I
observed was the gears at the back of the table (that moves the tone
arm across a record), appear dry and a little dusty.
Besides the possible need for cleaning and lubricating these gears, are there any other items I can check myself?
Finally, what type lubrication should I apply to the gears, and
is it possible that the belt is slipping, even though it doesn't appear
to do so?
Thanks,
Bill
