I have a Beogram 8000 that doesn't get a lot of use, but I leave it hooked up just in case. This morning I thought I heard the needle mechanism lift, and I look at the table and the platter is spinning so fast that I couldn't even see the plastic ribs which support the LP. I started pushing buttons to no avail, and literally had to pull the plug to get it to stop. Of course, now it won't power up.
Has anyone ever run across something like this before? Any ideas?
Thanks -
Chip Madinger
