moxxey:Alex does work in the Bath store, on a Saturday.
However, I agree with 355f. You will see a 'downgrade' by moving across to to the BV7-32, although a new version based around an improved chassis is due later this year. The current BV7-32 doesn't have any HDMI sockets, which are essential for the simple connection of modern equipment.
If possible, I'd wait. There's little point having Sky HD on the current BV7-32. Sky HD on the BV7-32 will be about the same if not a little worse than Freeview on your current Avant.
Wait until we hear what's happening with the BV7-32. We might know something after the dealer's conference this week.
Moxxey, i believe that the new bv7 will use the bv8 chasis, which is cheaper, but does have hdmi. i dont believe that its technically better.
Andy, we were in the exact same position, i had the exact same avant and moved to the BV7-32, that was faulty and no hdmi, then i returned it and got a BV7-40. The BV7-40 IS an AMAZING TV, i have to agree, much like the avant. the 40'' has completly dominated my room since its bigger than the fireplace!!!!
Since you said that you have a bc2, id stay put ;) the avant is sweet and its better worth its money. id stay put, since with the money ur going to spend on the bv7, you could upgrade something, or start link rooming? wait for the bs5 etc etc?
you cant loose, if u choose to stay put or upgrade, you wont regret it, but i dont think its thaaaat much worth it. my 1080p, bla bla bla, bv7 can play hd. up to this very date i have yet to play ANYTHING HD on it! the hd sources are not available, im thinking about a ps3, but would like to remain with b+o for an hd solution, regardless if its integrated into a newer bv7.
worse case, why dont u get a cheaper bv lcd/plasma? use that in the living room, and link ur avant to it?
