Hmmm...... my (new to me) beosound 2500 will not store settings.
Received from the auction site, price was right, tape was not working as well as no remote.
OK, so I replaced the belt and the tape works. On the remote, in stand-by press sound 1 store.
Everything works. I can program and set stations. It goes through all the motions, etc. As long as the power is on.
If I switch to stand-by, everything is lost. I have to re-program remote code, etc. A look at the battery shows 3.2volts.
I'd think the static ram IC is bad, except how does it remember all the settings when I don't turn it off?
Oh, and there's an empty socket next to the EPROM. Is this normal?
Any thoughts?
Marc
