I sold my 7700 Unit and purchased a 5500 with the master control panel.
 I have come across a few problems that i have no idea how to fix.
1. The master control panel works with the unit, but the display does not stay on, its like the unit keeps restarting every few secs, which is annoying because you cant set the time or preset radio functions.
2. The little door has broken hinges so it does not sit right, is there anyplace i can purchase a new door?
Thanks for your help in advance.
									    Bang and Olufsen Beomaster 5500, Master Control Panel 5500.
