Latest post 08-17-2008 9:59 AM by Craig. 15 replies.
Page 1 of 1 (16 items)
  • 05-17-2007 9:30 AM
    • Kevin
    • Top 50 Contributor
    • Joined on 02-15-2007
    • Moderator
    • Posts 1,256
    The Beolit FAQ under construction
    Always a popular product.
    Did you know that you can set pre-sets on the  tuning scale so you can easily find your favourite stations. Move the slider over the pimple, push down and slide to the position you want.
    The cardboard battery tube is often missing but is not essential to operation.
  • 05-17-2007 9:51 AM In reply to
    Re: The Beolit FAQ under construction
    Hi Kevin
    When you talk abour presets, do you mean on the Beolit 600/500/700/707 series? I don't have my 600 in front of me, so could you explain how this works as I don't understand (therefore highlighting the fact that a FAQ on the Beolits is a good idea!)?
    John
  • 05-17-2007 10:59 AM In reply to
    • Kevin
    • Moderator
    • Posts 1,256
    Hi John,
    yes, the perspex slider has a light groove in it in the slots of the frequency scale there are little plastic pimples which move along. When the perspex slider hits one of these it comes to a stop where you left it and hopefully the radio station you had wanted to save.
    Does that make sense? I'll try and do a picture when I get the chance.
    cheers,
    Kevin
  • 05-17-2007 12:20 PM In reply to
    That is only on the FM only 400, 500 and 505 models though. The 600, 700 and 707 use the ball bearing and magnet tuning scale with no presets.
  • 05-17-2007 1:15 PM In reply to
    Peter:
    That won't be me then. I have a 600!
  • 05-19-2007 6:38 AM In reply to
    • Kevin
    • Moderator
    • Posts 1,256
    Bump.
    Is this all we know and want to know about the beolits?Wink
  • 05-19-2007 8:57 AM In reply to
    To use the Beolit 1000 as an amplifier, attach the source to the Aux input and then press the P2 and P3 together. To utilise the external speaker, plug the speaker in the speaker socket with the pin facing to the rear. This will allow the speaker to work from the battery and can draw up to 2.5W. The internal speaker will switch off. If the Beolit 1000 is attached to a 7.5V source, the speaker can be attached with the pin at the front , in which case 7.5W will be available. The internal speaker will also still work when used in this way.
  • 05-20-2007 4:02 AM In reply to
    • dave1900
    • Not Ranked
    • Joined on 04-18-2007
    • gloucester
    • Posts 6
    Anyone know where I can get a replacement telescopic aerial for the Beolit 600??
  • 05-20-2007 11:49 AM In reply to
    Very difficult I am afraid.
    For those fans of Beolits, I am scanning a whole lot of service manuals for these. Will be on over the next day or so.
  • 08-15-2008 5:42 PM In reply to
    • madskp
    • Top 500 Contributor
    • Joined on 11-06-2007
    • Denmark
    • Posts 111
    • Gold Member
    dave1900:
    A little Danish radio and tv store called Bremdal Radio (it's actually located in Struer) had some made a few years ago. I bought a couple from them. The top is not exactly as the original but in my opinion it will do.
    I think the price was like 13,5 € or so.
     You can try to contact them. the contact information is on this page http://www.bremdal-radio.dk/kontakt.aspx
  • 08-16-2008 6:06 AM In reply to
    What happened to this thread - I thought it would be useful, though perhaps the level of responses tells its own story :(
  • 08-16-2008 9:45 AM In reply to
    I have put all the manuals on!
  • 08-16-2008 11:55 AM In reply to
    Peter :
    I know! The 800 one was mine that I scanned :)
  • 08-16-2008 5:23 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Am I correct in saying that on some Beolit models the FM scale only goes up to 104 mhz.
    CraigSmile
  • 08-16-2008 6:13 PM In reply to
    Not even that far on some:
    600 (1960s) goes to 100
    609 to 100
    600 (1970s goes to 104)
    800 goes to 108, but is older than the 1970s 600!
    Just run around the house checking my collection!
  • 08-17-2008 9:59 AM In reply to
    • Craig
    • Posts 4,855
    Thanks John, I was thinking of getting a Beolit some time ago for the Kitchen. This is what put me off, as the station I listen to the most is above 104. At the time I thought it was all models that went to 104, but later found out it was just some of them. There is a least one model of Beomaster which only goes to 104 too. Can't remeber which, even though I had one.LaughingLaughing
    CraigSmile
