My 1986 Master Control Link System 2 System Manual states:
As far as the operating principples are concerned, the MCL2A is identical with the previous MCL82, but in terms of technology the MCL2A has been adapted to B&Os A/V system. This also means that the MCL2A cannot be used with old Bang and Olufsen products.
The "old" products listed are the BM300, 5000, 6000, 800 BC 7000 7002 7007 and 7700 of which most will work with MCL82 - save the BM 3000 and 6000 (MCL30).
The manual is based on the use of BM3300 5500 and BC9000.
Brian
