What ho you folks!!
Well isn't it typical! You disappear for a few months & when you resurface to the land of the living you find that your system isn't working properly!!
I'm still using my lovely BM6500 as the amp, with my BC5500, BGCD6500 & PC running through it to the BV Cona & the RL140s - bass overkill, I know but if you've got it, rumble it...
All this was working 100% fine & loverly (to quote DVD) when I used it before, unplugged it all, moved the room around, plugged it all back in in exactly the same fashion, only to find that the sound is now horrendously faint, like I'm trying to power high powered speakers from a petty amp & if I turn it up enough to be audible (let alone monsterous!), the amp switches off to prevent the speakers overloading.
I'll bet that, as ususal, it's something simple that I've missed but, in the words of Penelope Pitstop - HAYLP!! [:'(]
Thanks, as ever...
ME!
PD
"The difference betwixt erotic & kinky is that betwixt using a feather & using a chicken..."
