Great Deck. Try tracking to half way through the record and see if the problem happens again, turn the deck off etc. Even move the arm backwards and forwards a few times, you don't need a record on to do this. It could be that the arm is not tracking at the correct speed, the caps have gone....
A myriad of strange problems can be fixed with the Cap kit from a member Dillen.
beoaus.
