Latest post 08-05-2008 11:12 AM by Christian. 1 replies.
Page 1 of 1 (2 items)
  • 08-05-2008 9:54 AM
    Beolink Passive gratis
    Does anyone want a B & O "Beolink Passive" main unit, free?
    This is just the heavy, big black box - no infra-red receiver or remote. It powers up, but I have no way of testing it further.
    There is a power cable. The infra-red, Master Link and speaker connectors are included, but they are cut off with only a few centimetres of cable attached. Rear panel says:
    Type 1656
    SW 1.4
    Serial no 17633887
    Item no 1165666
    Pick-up only from 2900 Hellerup, Denmark.
    If no one can use it, it goes in the trash.
    Thanks, Chris Adams.
    Google translation of the above:
    Er der nogen, der ønsker en B & O "Beolink Passiv" central enhed, gratis?
    Dette er blot den tunge, store sorte boks - ingen IR-receiveren eller fjernbetjeningen. Det beføjelser op, men jeg har ingen mulighed for at teste det yderligere.
    Der er et strømkabel. De infra-rød, Master Link og højttalertilslutninger er inkluderet, men de er afskåret med kun et par centimeter af kabel vedlagt. Bagside siger:
    Type 1656
    SW 1,4
    Løbenummer 17633887
    Varenr 1165666
    Pick-up kun fra 2900 Hellerup, Danmark.
    Hvis ingen kan bruge det, det går i papirkurven.
    Tak, Chris Adams.
  • 08-05-2008 11:12 AM In reply to
    • Christian
    • Top 100 Contributor
    • Joined on 04-16-2007
    • Copenhagen, Denmark
    • Posts 626
    Re: Beolink Passive gratis
    I would very very much like to pick it up.
    I live nearby in Østerbro, just give me your adress or phone and I will contact you to arrange a pick up. I have also sent you a personal message, please check your Inbox here on BeoWorld. You can also call me on +45 28114408
    Best regards
    Christian
    Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
    Addicted? Oh no.... ;)
