does anyone know the latest software for the bc2, also can you remind me how i get in the service menu to check, i have got the engineer coming next week to fit a longer scart cable as one supplied is to short, so if update is needed would make sense to do when he is here.
i bought this off my dealer at a reduced price as its mki i version audio dvd non dab, no reponse back on activation sensor wise
cheers from sunny canary isles
malcolm
never won in prize draw again sob sob
