HI,
HAS ANYONE SEEN THIS KIND OF PROBLEM OR KNOWS WHAT STEPS TO CORRECT? THE SOUND LEVEL LIGHTS ARE ON BUT THE ON/OFF SWITCH DOES NOT WORK ON EITHER THE UNIT OR REMOTE.
THANKS,
CHRIS BENNETT
Chris,
Based on your brief description, it sounds like a power supply fault
Regards Keith....
