Latest post 07-29-2008 1:46 AM by Peter. 4 replies.
Page 1 of 1 (5 items)
  • 07-29-2008 12:45 AM
    contacting moderators
    This is probably a ridiculous question, but how do I send an email to a moderator re subscription fees?
    Hope someone can help.
    Patrick
  • 07-29-2008 12:53 AM In reply to
    • Wings
    • Top 200 Contributor
    • Joined on 04-17-2007
    • Hong Kong
    • Posts 341
    Re: contacting moderators
    If you click on the moderator's name above the avatar, it will open a window which would allow you to send the moderator a Private Message; alternatively if an e-mail address is provided, you can use that means of communication.  I don't know if there is any particular moderator responsible for subscriptions, but perhaps 9 Lee or Peter would be your best initial contact.
  • 07-29-2008 1:01 AM In reply to
    Use the batlamp on the roof.
  • 07-29-2008 1:02 AM In reply to
    • Wings
    • Hong Kong
    • Posts 341
    Laughing  But he is not Commissioner Gordon or Chief O'Hara.   Smile
  • 07-29-2008 1:46 AM In reply to
    Lee is away at present - I must confess to not having a lot to do with the financial side but will help in anyway I can!
