Latest post 07-20-2008 5:20 PM by Peter. 1 replies.
Page 1 of 1 (2 items)
  • 07-20-2008 1:36 PM
    • henk66
    • Not Ranked
    • Joined on 07-20-2008
    • Posts 1
    Beomaster 8000 problems
    Hello, I have a beomaster 8000 that I bought second hand a couple of years ago. I want to use it but i has some problems.
    Sometimes the relays start clicking for a couple of seconds when turing on. Also, the receiver becomes more stable when it's warm.
    Sometimes the volume control distorts the sound (like it's turning on and of very fast). Any idea what the problem is?
    I cleaned the control and display contacts before, that help make it more stable for a while. Maybe he caps?
  • 07-20-2008 5:20 PM In reply to
    Re: Beomaster 8000 problems
    If it has not had the capacitors and variable resistors replacing, it will do! There are a lot of red capacitors in these beasts!
