Latest post 07-29-2008 3:41 PM by Olof. 2 replies.
Page 1 of 1 (3 items)
  • 07-29-2008 11:25 AM
    • Olof
    • Top 500 Contributor
    • Joined on 05-12-2007
    • Posts 141
    Is it possible to switsch of MX4200 centerspeaker if you use extra speakers ?
    Now it works that I bring in musik from my computer via the Scart conector of my MX4200 to my BeoLab 3. Is it possible to switch of the MX4200 centerspeaker if i listen musik, and switch it on if I am watching TV ?
  • 07-29-2008 1:46 PM In reply to
    Re: Is it possible to switsch of MX4200 centerspeaker if you use extra speakers ?
    Using the Beo4 select "Speaker" in the LIST menu followed by "1" for internal speaker only, "2" for external speakers only or "3" for all speakers.
    Have a look on page 11 of your users manual.
  • 07-29-2008 3:41 PM In reply to
    • Olof
    • Posts 141
    Thanks !
