kallasr: Does the week-end stopping surely work for the 9500?
As I read in the manuals only the 9300 support entering days (1 to 7 for mo through fri).
Hi Ralf!
The week-end stopping works for sure on the BC9500 (at least it does work on mine) but you'll need to program the timer with a two-way remonte (idealy the BL7000). Using an two-way remonte is, as far as I know, the only way to choose certain days when setting a weekly timer on the BC9500.
What if you don't own a BL 7000? Just a BL 1000 or Beo 4?
In order to fully use the BC9500's timer capabilitys you definetely need a two-way remonte. With a one-way remonte (as Beo4 and BL1000) you cannot acces the necessary programming options.
I strongly recommend using a two-way remonte with a BC9500 (or any other two-way system)... the best way to use the full potential of theese systems.
cheers
Foxtrott
									    "The first thing we do, let's kill all the lawyers."
Henry VI, Part 2 William Shakespeare
