Latest post 07-14-2008 8:09 AM by Razlaw. 6 replies.
Page 1 of 1 (7 items)
  • 07-07-2008 6:05 PM
    BV7 DVD eject
    Can the Beo 4 be used to eject on DVD on a BV7 MKIII?
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 07-07-2008 10:01 PM In reply to
    • Jez
    • Top 500 Contributor
    • Joined on 06-13-2007
    • Posts 150
    Re: BV7 DVD eject
    No, what's the point if you have to go get the disc out of the tray anyway. You can however close the tray with the remote, once you load the disc and sit down then press GO or DVD and it will close the tray.
  • 07-07-2008 10:54 PM In reply to
    • beoaus
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Melbourne, Australia
    • Posts 445
    Re: BV7 DVD eject
    You don't want your three year old learning how to open the tray...
    Try DVD then STOP....
    You can also use BLOCK SENSITOUCH on the service menu to stop the manual button.
    beoaus.
  • 07-08-2008 8:07 AM In reply to
    Re: BV7 DVD eject
    I tried DVD  STOP, no success.
  • 07-08-2008 5:21 PM In reply to
    • Tom
    • Top 25 Contributor
    • Luxembourg
    • Posts 3,175
    Re: BV7 DVD eject
    Razlaw:
    No, but the Beo5 an be programmed to do it.
    Music washes away from the soul the dust of everyday life. - Berthold Auerbach
  • 07-13-2008 10:00 PM In reply to
    • beoaus
    • Posts 445
    Re: BV7 DVD eject
    I'll have another look ...
  • 07-14-2008 8:09 AM In reply to
    Re: BV7 DVD eject
    If there is no DVD present, touching DVD on the Beo 4 does cause it to open.
