Latest post 07-18-2008 3:03 AM by joeyboygolf. 9 replies.
Page 1 of 1 (10 items)
  • 07-01-2008 4:22 PM
    Overture Tape Deck
    Hi:
    Quick question about the Overture.
    1) When I press "play" with no cassette loaded, the deck does nothing. (expected)
    2) When I press "tape" with no cassette loaded, the head block will engage and the spooling spindle rotate.
    It has been suggested that this a function to enable easier cleaning of the tape heads however I did not find reference to this in the manual.
    Is this a "feature" or a "fault?"
    Can you check if you own one or a derivative?
    Thanks,
    Derek
  • 07-01-2008 4:29 PM In reply to
    • rfc1
    • Top 500 Contributor
    • Joined on 02-06-2008
    • Posts 166
    • Gold Member
    Re: Overture Tape Deck
    Mine does same as yours except that it engages and spools when i press either play or tape.
    sandy
  • 07-02-2008 10:54 AM In reply to
    Sandy,
     Thanks for your reply!
    Derek
  • 07-02-2008 1:59 PM In reply to
    When I press play or A-Tape my Overturn doesn't engage at all.......
    Lets hope its not broken!!!!!
    :-s
    GUY
    Train Hard - Run Fast - Hit to Kill!!!
  • 07-16-2008 6:34 PM In reply to
    Guy:
    Thanks for your response.
    So this is strange 3 units of the same model, 3 different behaviors?
    Can we have a larger sample from other members?
    Thanks,
    Derek
  • 07-17-2008 8:39 AM In reply to
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    My ouverture did the same thing as yours did Derek, i don't think there's anything to worry about.
  • 07-17-2008 1:57 PM In reply to
    • beodim
    • Switzerland
    • Posts 130
    Derek, my Ouverture does the same operation as yours, too.
    BV7-40, BC6-26, DVD2, BCordV8000, BS4, BS2, BS Ouverture, BC9500, BM8000, BCord9000, BL8000, BL6000, BL2, BL3, BVox4500, BCom6000, Beomedia1, BCom5, Serenata
  • 07-17-2008 7:35 PM In reply to
    Re: Overture Tape Deck / 2way IR?
    Dave, Beodim:
    Thank you for your response. Now I can sleep better :)
     BTW, do you know if the Overture supports 2way remote? Mine comes with the Beo4 but thinking of getting the BL5000.
    Thanks,
    Derek
  • 07-18-2008 3:03 AM In reply to
    • Foxtrott
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Vienna, Austria
    • Posts 500
    auric:
    Hi Derek!
    The Ouverture is a one-way product. From this design series only the Beocenter2500 and the early BC2300 were two-way capable.
    As for the Beolink5000 itself: Designwise a nice remonte but not very durable (contrary to the Beolink1000 or the Beo4). Pixel faults in the display (missing lines) a very common and not easy to repair as the display cannot be changed without changing the whole printboard.
    cheers
    Foxtrott
    "The first thing we do, let's kill all the lawyers."
    Henry VI, Part 2 William Shakespeare
    2 way stopped with the demise of the 2500 as far as I know.
    Regards Graham
