Latest post 05-18-2007 5:38 AM by zor. 2 replies.
Page 1 of 1 (3 items)
  • 05-18-2007 2:03 AM
    • zor
    • Not Ranked
    • Joined on 05-18-2007
    • Posts 2
    LINTRONIC learn ir code problems
    I don't find ir codes for sony str da or db 2000 es.(can't find on remote central) I have tried to read out the ir (with an external ir sensor connected to the module) from the sony remote rm pp412, without results i can use. I see the ir string and i have try to change the time pulse. Who is specialist to read out ir codes from a remotecontrol? Thanks for any help
  • 05-18-2007 3:53 AM In reply to
    • GSHaigh
    • Top 500 Contributor
    • Joined on 04-16-2007
    • North West UK
    • Posts 163
    Re: LINTRONIC learn ir code problems
    Hi
    I see that Michael now has a new Lintronic forum, http://www.lintronic.dk/forum/default.asp , you might be better off posting there?
    Greg
  • 05-18-2007 5:38 AM In reply to
    • zor
    • Not Ranked
    • Posts 2
    Ok, that's a good tip, thanks!
