Martin,
My frustration level with this Beogram 8000 has reached the point where it is best left alone for a while.
Five plus hours to VERY carefully install your cap kit have rendered this turntable useless.
Needles to say, the problem is not the fault of your fine kit, but something has occurred to make the platter rotate backward with the platter in place.
Plug in the turntable and the platter rotates backwards and the sensor lamp blinks.
Two friends have insisted that something is backwards most likely dealing with the power supply, but I didn’t do anything with the power supply.
I am sure that when the dust settles I will have another go at it, but right now the 8000 has joined the 4000 and 4002 in the non-working category.
Jeff
