Latest post 06-28-2008 4:59 AM by Peter. 2 replies.
Page 1 of 1 (3 items)
  • 06-27-2008 6:33 PM
    Compatibilty Beolink7000 RDS
    Hi all,
    does anyone know how "compatible" a Beolink 7000 is when using with an Avant 8420 and an Ouverture?
    I realize that the 2 way communication won't work- but will everything else?
    Thanks in advance
  • 06-28-2008 3:45 AM In reply to
    • RayTheWash
    • Top 500 Contributor
    • Joined on 04-16-2007
    • South East London
    • Posts 93
    Re: Compatibilty Beolink7000 RDS
    I use mine to drive a Beosystem 7000 and a Beocentre 1 in the same room with no problem.It works two way with the 7000 and one way with the TV without having to change any settings.
    Regards
    Ray
  • 06-28-2008 4:59 AM In reply to
    It will work but you will find it a little slow and not as intuitive as a Beo4. Very pretty though!
