I should have known better really than to buy an 'untested' MMC 6000 from ebay, but I can't really afford a new Soundsmith at the moment, and can't really justify the cost, because i'd want the CL at a minimum if I had to buy new!
The cart came in the post today, and it sounded great - in one channel!
I tweaked the contacts to no avail, so I broke out the multimeter, and sure enough, one channel was open circuit.
Its a shame because cantelever and stylus look pristene, and the suspension appears great.
Anyway, I thought i'd at least get some use out of it.... I took the guts out of a good MMC20E and put them inside the MMC6000 casing! At least the cart now matches the arm. And yes, the picture is of my creation, and it seems to work just as well as it did before.
Anybody have a working MMC6000 or 20CL they want to dispose of for a fair sum?
