Can anyone help with the following problems with a MCL set up.
I have attached a diagram of my existing set up to which I am having some problems.
The reason for the two MCl-2A in the main room is that is a very large space and I basically needed 2 tranceivers to be able to control everything OK. The tranceivers can not see each other and it works pretty nice as I can "mute" one section of the space if I want to. I recently added a MCL-2AV to the TV/Link Room 1 as I wanted to be able to get audio into this room (Radio, CD, or Aux/Tape1 (PC iTunes)).
This is how I have option programmed everything (basically option 2 for everything):
Main Room
Beomaster 6500: standby - sound - 2 - store
MCL-2A (both): standby - link - 2 - store
Link Room
MX4000: standby - picture - 2 - store
(I don't know if I would need to program an option for the MCL-2AV? I tried to program option 2 to this as well by pressing: standby - link - 2 - store, but I didn't get any flashing "confirmation" that this was received OK)
I have connected the MX4000 TV from its "Audio Aux Link" to the MCL-2AV "Aux" port.
PROBLEM 1:
Basically what is happening if I change the Audio source, or switch off in either room, the other room is changing/switching off as well
- If the main Room audio is on and playing ie. CD and I turn on Radio in TV/Link Room, the TV's speakers are activated with Radio, BUT the main rooms audio also switches to Radio, and the Main Rooms volume goes up high. After this, changing the volume in the Main Room also changes the volume in the Link Room, but changing the volume in the Link Room does not affect the volume in the Main Room.
PROBLEM 2:
- Main Room in Stand-By mode
- I turn on ie. CD in TV/Link room. Tv's speakers comes on slowly, gradually raising the volume, BUT now with a really bad sound quality (almost like the speakers are blown - which they are not)
- If I now turn on CD in the Main Room, the volume starts on really high and the TV's volume goes down very low.
NOTE: When the Main Rooms audio is on, the sound quality in the Link Room is perfect!
I would be very grateful for any help on what I can do to recitfy these problems. Many Thanks,
Patrik
