Latest post 06-17-2008 4:02 PM by ezinternet. 2 replies.
Page 1 of 1 (3 items)
  • 06-14-2008 1:26 AM
    • ezinternet
    • Not Ranked
    • Joined on 06-13-2008
    • Chicago IL USA
    • Posts 2
    Hmm [^o)] How to Select Source A.Tape2 with Beolink 5000 ?
    Hi All - First post here; hope you can help Unsure
    I've got Beosystem 7000 and I hooked up an Apple Airport Express to feed into source Tape2. This works great when selected using Beolink 7000, the large system remote.
    But, is there a way to select that input source, A.Tape2, using my Beolink 5000 remote? I didn't see anything in any documentation for the system or remote that gives me a sense of how to choose A-audio sources beyond the buttons that are provided: CD, Radio, Phone, Tape.
    Thanks!
    --ez
  • 06-14-2008 2:47 AM In reply to
    Re: How to Select Source A.Tape2 with Beolink 5000 ?
    Try SHIFT, A.TAPE. The SHIFT button is on the back.
  • 06-17-2008 4:02 PM In reply to
    • ezinternet
    • Not Ranked
    • Chicago IL USA
    • Posts 2
    Of course that did it. Thanks!
    I was treating SHIFT like a keyboard and pressing it simultaneously rather than sequentially with the other source key.
