So, I have an old Beomaster 4500, and I'd like to get my computer connected to it.
I have an old tape recorder that we don't use, and it had these 7-DIN -> 4xRCA connectors in each end.
Does anyone have the pin order I have to use to get audio from a 3.5mm plug from my computer to those RCA connectors?
I've tried to fiddle with it, so far the sound either comes from only one speaker and sounds completely rubbish, usually with high and low sounds completely cut out, or it just doesn't work.
