Latest post 06-11-2008 2:32 PM by Jandyt. 1 replies.
Page 1 of 1 (2 items)
  • 06-11-2008 2:14 PM
    Avant Aspect Ratio
    Hi folks
     I have recently obtained one of the older 'VHS' Avant models, and I am getting 2 black lines down either side of my picture! Is this normal? Or is there a way to get the picture to 'fill' the screen? I couldn't see any way to change the aspect ratio in the menu. I am currently using it with an ordinary aerial, no sky or digibox or anything like that!
     Any advice much appreciated!
     G
  • 06-11-2008 2:32 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Re: Avant Aspect Ratio
    Which remote are you using?
    If Beo4, you need to add 'format' to your list and use that.
    If Beolink 1000, the use the 'picture' button. Hope this helps.
    Andy T.
    Poor me, never win owt!
