Latest post 06-05-2008 3:28 PM by jk1002. 7 replies.
Page 1 of 1 (8 items)
  • 06-05-2008 12:20 AM
    BV8 and BC2 Question - Delayed Sound for Music
    I have a BC2 connected to a BV8. My speakers are attached to the BV8 as well.
    What bugs me a bit is, if I put in a music CD, it starts playing, however it takes 3 to 5 seconds until my BL3 speakers that are connected to the TV turn on.
    I have scart and ML connection between BC2 and BV8.
    Any ideas if this is normal which I doubt or if I can re-configure that thing somehow? It does not happen when I connect the speakers straight to the TV but that somehow defeats the purpose.
    Cheers
    JK
  • 06-05-2008 5:32 AM In reply to
    Re: BV8 and BC2 Question - Delayed Sound for Music
    I have scart and ML connection between BC2 and BV8...
    The SCART connection is enough...
    Jq. BS4 BL3 A8 Form2
  • 06-05-2008 5:50 AM In reply to
    Not correct.
    The BV8 & BC2 needs to communicate to each other trough the ML... so both are needed! Especialy for the audio part.. (CD/Radio)
    The race for quality has no finish line- so technically, it's more like a death march.
  • 06-05-2008 7:25 AM In reply to
    I use them wiothout ML connection and the sound & pic run OK Hmm
    question is still there, why do the BL3 need a few seconds to turn on. This is not the delay caused by the BC2 checking if it is a DVD or CD. The CD is actually playing.
  • 06-05-2008 9:35 AM In reply to
    Very strange... Since the BL3's are connected to the BV8... Do they also need that much time when you start up the TV?
  • 06-05-2008 2:42 PM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    xegoon:
    The scart can only be used to activate the DVD player - not to activate it as a CD player or use the Radio section. You can play CDs through the DVD function, but it's better not to IMO.
     Weekly top artists:
  • 06-05-2008 3:28 PM In reply to
    No, its right there. Same for DVD ..... I am thinking it's a software issue .....
