Latest post 05-11-2007 6:28 PM by Tom. 9 replies.
Page 1 of 1 (10 items)
  • 05-11-2007 12:30 PM
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    BeoSound 4 - HiFi credible?
    Is the BeoSound 4 only really suitable for the likes of BL6000, BL4, BL8000 etc? Or can this player be successfully used with BeoLab 5 without a deterioration in sound ability?
    I've read that it is budget, and i've only seen it setup with those hopeless BL4 speakers...
  • 05-11-2007 12:32 PM In reply to
    Re: BeoSound 4 - HiFi credible?
    I think it is fine - though it does not have a digital out. Seems to be similar to the BS3000/3200 in concept and performance.
  • 05-11-2007 12:42 PM In reply to
    • Dave
    • Posts 2,328
    I noticed it doesn't have digital out, but i'm curious if i will miss out on better sound without a digital connection. I'm suspecting (and hoping) that the innards of the BeoSound 4 are the same as the BeoCentre 2?
  • 05-11-2007 12:45 PM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Actually I thought the BeoSound 4 was a step ahead of the 3200 in terms of radio performance. Can't say I've noticed much difference with CD, as you say, only demonstrated with BeoLab 4s which are pretty hopeless in terms of a 'decent hifi demonstration'. When I compared the BS4 vs BS3200, it was BeoLab 4000s vs BeoLab 3s being driven, but with the BS4, the sound was actually more detailed, which isn't what you'd expect considering the BeoLab 3s were connected to the 3200...
     Weekly top artists:
  • 05-11-2007 12:54 PM In reply to
    • Tom
    • Luxembourg
    • Posts 3,175
    I have heard the BS4 connected to a pair of BL8000, and the sound was very detailed and clear. I would though say, that the BS4 is a big step behind BC2 and BS9000, due to the missing digital output. If I wanted to drive a pair of BL5 or BL9, I would not choose the BS4, because I think you could enjoy your speakers a lot more with BC2 or BL9000.
    Music washes away from the soul the dust of everyday life. - Berthold Auerbach
  • 05-11-2007 12:59 PM In reply to
    • Alex
    • Posts 2,990
    I would agree with you, but if you only use the PowerLink outputs, I reckon the BeoSound 4 will give better performance...
     Weekly top artists:
  • 05-11-2007 1:04 PM In reply to
    • Dave
    • Posts 2,328
    I love the BS4, but i want to know for sure what the difference is between the digital connection and the powerlink connection. It isn't something you can just guess, and a salesman isn't really going to give me a straight answer as they still work for commission.
  • 05-11-2007 1:07 PM In reply to
    tom:
    But the BL9s don't have a digital input. The display in the BS4 is the same as the BC2. There is of course the new Audio BC2 - tricky to see what it offers over the BS4 except the digital out.
  • 05-11-2007 1:15 PM In reply to
    • Dave
    • Posts 2,328
    Peter:
    Exactly.
    Sorry, i should have stipulated, my comparison is between the BS4 and BC2 audio, i own the latter, but dislike it for it's petty design, the crappy click sound when it closes and it's plasticky CD surround.
  • 05-11-2007 6:28 PM In reply to
    • Tom
    • Luxembourg
    • Posts 3,175
    Peter:
    But the BL9s don't have a digital input...
    should have known that. was discussed here.
