I have a volume control problem on this machine but it should be fairly straightforward to fix. The volume up works OK but there is no volume down response. I downloaded the relevant service manual from the site and that is where the confusion starts.
The cover of the manual says "Beomaster 2400, Type 2901". My machine is the Beomaster 2400-1 but it is also marked as a Type 2901. However, it is clear that my circuit boards bear no resemblance to the ones in the manual. I thought that the "Type number" related to a fixed configuration for any machine? Can anyone help direct me to a correct copy of the circuit diagram for board 3? I am assuming that small board still contains the volume control circuits even though it looks a lot more complex than the older 2400 board.
Any help or pointers in the right direction would be appreciated.
Geoff
