Jandyt: In which case, Tony the part number is 3281044
Andy T.
Sorry to disagree with Andy ( had to be a first time !!
) but the part number for a later version button set is actualy 2776010. 3281044 is no longer in use.
On a related note, Denmark revised ( up and down ) the spare parts prices on 1st June, so anyone needing "bits" should be aware they may be dearer - or indeed, cheaper, than previously quoted.
This rubber keypad should cost you about £12 UK.
Bang & Olufsen of King Street - Manchester,UK. SKYPE - beokingstreet
