Latest post 05-26-2008 2:31 PM by stotty1111. 9 replies.
Page 1 of 1 (10 items)
  • 05-25-2008 8:37 AM
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    Tuning of MX5500 tv
    hi all
    just bought one of the above - tried it using 1000 remote - cannot work out how to use it to tune in tv stations - it came from another regional area - so quality of reception not good nor are stations registered
    please help
    salut
    tony s (currently uk based)
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 05-25-2008 9:27 AM In reply to
    Re: Tuning of MX5500 tv
    "Goto"- ">" and the MX will start searching channels.
    "Store"-"number..."-"Store" will store it on a selected channel nummer
  • 05-25-2008 9:43 AM In reply to
    • Ignace
    • Top 25 Contributor
    • Joined on 03-30-2007
    • Moderator - NL
    • Posts 2,749
    If you have to switch between tv-systems, press SHIFT + 3.
  • 05-25-2008 2:37 PM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    thanks guys now i appreciate the benefits of bno video - i've just had audio kit to this point - my tv cost 99p got to be a contender best buy stakes!
    cheers
    tony s
  • 05-26-2008 7:54 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Another question - is this multi region ie secam /pal etc or just aimed at the uk market - ie pal?
    thanks
    tony s
  • 05-26-2008 8:02 AM In reply to
    The MX5000 supports colour system PAL B/G --  PAL-L and PAL-I for the UK as well as Secam for places like France as well as Type 3251 supporting NTSC A/V 4.43 MHz / 3.58 MHz
    Regards Keith....
  • 05-26-2008 8:50 AM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    According to the MX5500 manual, the units sold in the UK are equipped to receive PAL I only.
    and they are not equipped to receive the PAL/SECAM B/G or SECAM/L systems.
  • 05-26-2008 10:05 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Thanks for the inf - my unit is a 3263 version  -  will try thr shift 3 when i get the chance to
    again many thanks
    tony s
  • 05-26-2008 2:10 PM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    If you would connect a Beocord VX5000/5500 to the MX 5500,
    you could distribute audio&video to another room.
    Smile
    Have you connected the MX 5500 to one of your Beocenters ?
    sound from tv through Beocenter-speakers, sound from Beocenter through tv-speakers.
  • 05-26-2008 2:31 PM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Big Smilenot yet - need to make up some leads - previously used the bc's with an lg lcd screen and a grandin screen - the mx5500 will replace the lcd in the main viewing area - one bc in france 9300 = the other in uk - normally live at the french address with penta's - the uk uses wharfedale speakers
    well pleased with both systems!
    just need to locate a set of keystrokes for the 1000 remote to fully control the mx5500!
    cheers
    tony s
