I don't know if it is the same with CRTs. However, to get burn out of plasmas, you can fill the screen with a white source and leave it running, this will remove other colour burns.
One option would be to connect a vhs up that typically has a blue OSD. If you can change the background colour to white and remove all symbols from the screen. Obviously it won't work if you leave symbols on the screen etc as it will burn these in instead.
